1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Planned changes to ASYN drvAsynIPPort
To: TECHTALK Tech-Talk <[email protected]>
Date: Fri, 11 Dec 2009 13:48:28 -0800
I plan on making a couple of changes to the ASYN TCP port driver.  Here's the salient portion of the release notes:
drvAsynIPPort
1) A return of 0 from a read of a TCP stream is treated as an END condition rather than as an error. This makes it easier to handle devices that close the connection at the end of a reply.
2) Support has been added for devices such as web servers that require a connect at the beginning of each transaction. To enable this behaviour, specify "http" as the protocol in the drvAsynIPPortConfigure command and ensure that each transaction ends with a read that detects the broken connection from the device. Note that the device will always appear connected. The connect/disconnect around each transaction is handled within the drvAsynIPPort driver.
I hope that these changes are neither too controversial nor too disruptive.  The first one I believe falls under the "principle of least surprise" and the second takes effect only when changes are made to a startup file command.
Eric Norum
[email protected]
P.S. Thanks go out to Marty Kraimer and Mark Rivers for their help in making these changes.
Prev: Re: Reading an array of strings from a Waveform record Andrew Johnson
Next: RE: Rethinking asyn motor drivers matthew.pearson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EDM GUI disable/enable Ralph Lange
Next: displaying areaDetector Video with EDM or MEDM John Dobbins
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
