Dear Tech-Talk,
It's the holiday season which means new computer (for my dad this
time) and also compiling code :)
So I tried installing EPICS et al. on a MacBook Pro (2.53 GHz) running
10.6.2 with MacPorts 1.8.1.
EPICS 3.14.11 went fine, although I needed to deactivate readline
(6.0.000_2+darwin) as it caused an error – hopefully a problem on
their end as the package is still in dev, but just in case here is the
error message
<snip>
../../../../bin/darwin-x86/antelope -l -d ../parse.y
dyld: Symbol not found: _rl_insert
Referenced from: /Users/Superior/Documents/EPICS/base-3-14-11/lib/
darwin-x86/libCom.3.14.11.dylib
Expected in: flat namespace
<snip>
When I try to compile the latest version of the alarm handler or MEDM
I get the following error message:
<snip>
ld: warning: in /opt/local/lib/libXmu.dylib, file is not of required
architecture
ld: warning: in /opt/local/lib/libXm.dylib, file is not of required
architecture
ld: warning: in /opt/local/lib/libXt.dylib, file is not of required
architecture
ld: warning: in /opt/local/lib/libX11.dylib, file is not of required
architecture
Undefined symbols:
"_XtAppAddActions", referenced from:
_awRowWidgets in awAlh.o
<snip>
I double checked the CONFIG_SITE.darwin-x86.darwin-x86 file to make
sure it is looking in the correct locations:
# XDarwin
X11_LIB=/usr/X11R6/lib
X11_INC=/usr/X11R6/include/X11
XPM_LIB=/usr/X11R6/lib
XPM_INC=/usr/X11R6/include/X11
# Fink OpenMotif
#MOTIF_LIB=/sw/lib
#MOTIF_INC=/sw/include
# DarwinPorts OpenMotif
MOTIF_LIB=/opt/local/lib
MOTIF_INC=/opt/local/include
Looking in the XDarwin directory there are three of the four .dylib
libraries (libXm.dylib isn't there).
Does someone have an idea of why the compilation is failing? Is it due
to the X11 not being the latest version? On my PowerBook I have
XQuartz 2.4.0 installed, but the XQuartz project said there would be a
separate release called 2.4.1 for Snow Leopard.
Bertrand
- Re: Compiling alh, MEDM on Snow Leopard (10.6.2) Steve Shoaf
CAJ or PV gateway problem? Mark Rivers
<2009>
2025
2026
<2009>
2025
2026
