I've been trying to make the ArchiveViewer work, but no such luck. I have managed to set up the ArchiveDataServer correctly, or at least I think so. When I connect to the server with ArchiveDataClient.pl I receive the channel list when I use the -l handle. But whenever I use the -i handle to receive the server information, I get the: 500 Internal server error. Anyway, when I try to connect to the server via ArchiveViewer I always get the same error like when using -i handle with ArchiveDataClient.pl - Internal Server Error. So, my question is: - Does it even look like the server is set up correctly ( i get the channel list with even the right timestamp ) - I cannot get the server info using ArchiveDataClient, but get the channel list - I cannot connect to server using ArchiveViewer I hope i gave enough info so you can point me into the right direction. Thanks in advance and merry christmass. Blaz
| ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
