You could do that with an scalcout. But you would not use the streamDevice support, you would just use the soft device support, since you have already read the string with the stringin record (using streamDevice?).
But maybe you should back up a step. Are you trying to read a string from a device, and convert it into a number, for example for an ai or longin record? If so then you should just use the streamDevice support for the ai or longin record directly, there is no need to use stringin or scalcout. Just write a protocol file for the ai or longin and provide the format string needed to decode the string.
Sent: Thu 12/24/2009 10:04 AM
To: tech-talk
Subject: how to use scalcout record in streamdevice?
hi,
I want to try scalcout record in streamdevice, but I still can't use it after reading some example or document of streamdevice.
for example, if I use stringin record to get a string like "12345678", then I want to convert it from ascii code to digital 12345678, can it be implemented by scalcout record?
can anyone give me a hint? thanks a lot in advance.
Best regards
Geyang 2009-12-25
- how to use scalcout record in streamdevice? Silver
Re:RE: how to use scalcout record in streamdevice? marco_hair
<2009>
2025
2026
<2009>
2025
2026
