1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Revision tracking on vendor supplied updates?
To: "Josh Stein" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Tue, 5 Jan 2010 13:42:52 -0500
Title: RE: Revision tracking on vendor supplied updates?
The interface to these devices increases.
If it is clean in function and interface, any upgrade should carefully consider what gets upgraded. The cost of hardware is relatively cheap to the cost of labor. It would seem that upgrades should first ask the question: what do I accomplish. Then the upgrade path considered: the entire blob of hardware is more likely a better answer than a software upgrade of a poorly understood black box. If it ain't broke - don't fix it. If you need something new - consider replacing the whole thing.
The NSLS II is developing these devices for motion control, BPM, power supply, fast feedback, and of course PLCs. We certainly push for open source developments and products. Our position is that products that do not make their source, drawings, firmware available are considered less desirable vendors. The goal is to have everything able to be supported in house.
RE: Revision tracking on vendor supplied updates? nick.rees
Re: Revision tracking on vendor supplied updates? Steven M. Hartman
Revision tracking on vendor supplied updates? Josh Stein
Prev: Revision tracking on vendor supplied updates? Josh Stein
Next: RE: CAJ or PV gateway problem? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Revision tracking on vendor supplied updates? nick.rees
