1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CAJ or PV gateway problem?
To: [email protected]
Date: Wed, 6 Jan 2010 11:58:54 +0100
Hi, all!
2 issues, 2 answers...
1) CAJ and JCA do not read environment variables
When CAJ was written reading env. variables was obsolete in Java (1.4). Now is back.
I got a request from SLAC to implement reading env. variables for CAJ and also for JCA.
It can be enabled with a special switch (for backward compatibility). Default is not to use env. variables.
If you all agree, I can change the default.
2) CAJ is broadcasting to 255.255.255.255.
Prior Java 1.6 it was not possible to introspect all network interfaces. So I was forced to use 255.255.255.255 as auto address.
Still I want CAJ to run on older Java version than 1.6. (Anyway, what do you use?)
What to do (options)?
1) detect java version and if 1.6 use introspection to get broadcast address of each network interfaces (might not be best solution since behavior is not the same)
2) I got one proposal from APS to use special env. variable that determines netmask; this would allow me to change 255.255.255.255 to e.g. 192.168.0.255 (but still only one network IF!)
3) ... any suggestion from you :)
I guess I should go 1) and for older versions non-auto address list should be used.
Cheers,
Matej
RE: CAJ or PV gateway problem? Chu, Paul
Re: CAJ or PV gateway problem? J. Lewis Muir
RE: CAJ or PV gateway problem? Mark Rivers
Prev: RE: Revision tracking on vendor supplied updates? nick.rees
Next: ca_pend_event fails to return Chris Slominski
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: CAJ or PV gateway problem? Mark Rivers
Next: RE: CAJ or PV gateway problem? Chu, Paul
