1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mbboDirect problem
To: [email protected]
Date: Wed, 6 Jan 2010 13:25:23 -0600
Hi Dirk,
On Wednesday 06 January 2010 03:37:53 Dirk Zimoch wrote:
> It is a pity that the Bx fields of mbboDirect do not update when VAL is
> written. It seems mbboDirect has not been designed to have VAL written.
> But then neither DOL not the record_init() code makes much sense. Maybe
> this is an issue for the next Codeathon. Provided we have defined what
> the "expected behaviour" is.
To add a little history to the discussion, the mbb*Direct record types were
created from the mbb* record types at JLAB.  I suspect that their deficiencies
have not been corrected because their original author lost interest and nobody
else has been sufficiently motivated to fix them before now.
I have a couple of private emails about a patch to the mbboDirect record from
September 2008, but the suggestion at the time was that more changes were
still needed, which was one of the reasons why I didn't apply the change.
I would certainly encourage anyone who wants to work on improvements to do so
(and publicize that you are doing so), although if you make significant
changes to the configuration fields or runtime behaviour it might be advisable
to rename the record type at the same time so that existing IOCs which may
rely on the current behaviour do not break when upgraded to a release
containing the new version.  It is then trivial to deprecate the old record
types and unbundle them from Base while still making them available for
existing installations to use.
> I propose the following behavior:
I haven't examined your specific suggestions, I'm happy to let you, Stephanie
and others to work on the details.  I would like reference documentation to
accompany any new or modified record type.
> What about extending the mbb* records to 32 bits?
I don't understand what you mean by that; the VAL field of the mbb[io] records
is a DBF_ENUM (i.e. an index into a list of choices) and you can't change the
underlying type for the index value.  The xxVL, RVAL and MASK fields are
DBF_ULONG and thus 32 bits wide already.
If you meant to increase the number of choices possible from 16 to 32, I'm
afraid that is currently limited by the CA network protocol and API which was
only designed to transport at most 16 state strings.  That limitation is
likely to be removed at some point, but it will not be possible to make the
result backwards compatible so existing CA clients will have to be modified to
use more than 16 states.
If you meant extend the mbb[io]Direct records to 32 bits though, I think that
has already been done by at least one site and does seem worthwhile.
> Heretic question: What about combining the features of mbb[io]Direct
> with mbb[io], i.e. adding Bx fields to mbb[io] records and get rid of
> mbb[io]Direct?
I don't see any major advantage to doing this, since the record types are
really very different in purpose.  The mbb[io] records allow a series of state
names to be associated with specific bit patterns, whereas the mbb[io]Direct
records allow individual bits in a word to be separated out and combined.  The
only overlap between these is in the I/O of the raw value; sharing device
support between record types will need a whole new record/device interface to
be developed though...
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: mbboDirect problem Ralph Lange
Re: mbboDirect problem Dirk Zimoch
RE: mbboDirect problem Allison, Stephanie
Prev: RE: CAJ or PV gateway problem? Chu, Paul
Next: Re: mbboDirect problem Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: mbboDirect problem Allison, Stephanie
