1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Odd MEDM behavior on OS-X
To: "Josh Stein" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Wed, 6 Jan 2010 14:05:20 -0600
Can you isolate the problem to the X server or client?  What happens if
you run the same version of medm on a Linux system and display on your
Mac, or run medm on your Mac and display on Linux or Windows?
-----Original Message-----
[mailto:[email protected]] On Behalf Of Josh Stein
Sent: Wednesday, January 06, 2010 2:02 PM
To: EPICS tech-talk
Subject: Odd MEDM behavior on OS-X
Ok, we're having an odd problem here at APS which has myself and others
scratching our heads.
When running MEDM on my Mac (OS X - Leopard) I am able to open and
execute existing screens, but when I try to add an object (using the
object pallet) things get bizarre. I am unable to successfully interact
with any of the object buttons within the palette (so, for example, if I
wanted to place a static rectangle using the drawing object, I cannot
seem to get that button to "press"). All buttons within the object
palette are similarly crippled.
Other uses of the mouse button within MEDM seem fine - for example when
a screen is operating and connected to PVs, I can click on related
displays, or other controllers and have them function properly.
Furthermore the other two palette types (Resource and Color) function
fine.
I realize I can place objects by right-clicking on the display - but
something has changed recently, as I've traditionally always used the
object palette.
Any ideas? Our Mac people have tried differing versions of the OS with
no difference noted.
--Josh
Re: Odd MEDM behavior on OS-X Josh Stein
Prev: Odd MEDM behavior on OS-X Josh Stein
Next: Re: Odd MEDM behavior on OS-X Josh Stein
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
