1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streamDevice and I/O Intr processing
To: [email protected]
Cc: [email protected]
Date: Wed, 13 Jan 2010 09:10:26 +0100
Hi Jens,
What I was trying to do by reading with timeout 0 is to poll if any data has been arrived during the last poll period. That asyn returns "timeout" even when there is input is somehow unexpected to me. I will check your modification.
Dirk
[email protected] wrote:
Hello all,
I ran into a problem when reading from a serial device using I/O Intr processing with streamDevice.
The device sends a string every 100 ms and this string is converted into numbers using scalcout record ( silly spaces between sign and numbers fail ai record conversion).
The conversion works, but depending on the poll period, I loose a lot of strings.
If using a poll period of 50 ms, I get none conversions at all.
100 ms poll period converts about every other string, 500ms poll period converts 4-5 strings every 500 ms.
This is the db:
record (scalcout, "VRZ720:$(host)$(port)02") {
    field (DTYP, "stream")
    field (OUT,  "@VRZ720.proto getYAxis VRZ01")
    field (SCAN, "I/O Intr")
         field (CALC, "AA=='-'?-1*A:A")
This is the protocol:
InTerminator = LF LF;
PollPeriod = 50;
ReadTimeout = 30;
getYAxis {
in "X=%*[+-]%*f%*[ RDrd]\r\nY=%(AA)[+-]%(A)f%*[ RDrd]\r";
This is an example string, which is sent to the device every 100ms.
X=- 757.4302 R\r\nY=-  75.6267 R\r\n\n
The problem is caused by the first call to pasynOctet->read with readTimeout 0 if EOS is set.
If using eos asynInterposeEos will return asynTimeout even if some characters have been
received, but not yet the eos-string. The timeout aborts the stream protocol and the partial string is discarded. If using a long poll period chances grow, that a full string is in the
buffer at the first read which will be properly processed. But you don't want to process
only once a second, if strings are delivered every 100 ms.
If preventing the stream protocol from aborting, even if the first read is a timeout, allows to read again and accumulate partial strings until eos is received.
The second call to pasynOctet->read has timeout=ReadTimeout, which must be long
enough to read the full string.
I attached a patch (which hopefully doesn't break existing code) to do this.
Jens
--- old/AsynDriverInterface.cc 2010-01-08 16:46:59.870812999 +0100 +++ new/AsynDriverInterface.cc 2010-01-08 17:05:33.404224396 +0100 @@ -807,6 +807,11 @@ } // pasynOctet->read() has already cut off terminator.
+ // Timeout is considered success, if reading with EOS in AsyncRead
+ // mode and at least one octet was received
+ if ((status == asynTimeout) && streameos && (ioAction == AsyncReadMore))
+ status = asynSuccess;
switch (status)
case asynSuccess:
@@ -823,7 +828,16 @@
// ignore what we got from here.
// input was already handeled by asynReadHandler()
// read until no more input is available
- readMore = -1;
+ if (streameoslen && (eomReason & ASYN_EOM_EOS)){
+ if (replyTimeout != 0.0) {
+ ioAction = AsyncRead;
+ startTimer(replyTimeout);
+ readMore = 0;
+ else {
+ readMore = -1;
break;
#ifndef NO_TEMPORARY
streamDevice and I/O Intr processing Jens . Eden
Prev: Software Architect Position at the Thirty Meter Telescope Corinne Boyer
Next: Device support for Intelligent Instrumentation EDAS-1000 Rod Nussbaumer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: streamDevice and I/O Intr processing Jens . Eden
Next: 2 Group Leader openings at the APS Andrew Johnson
