1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm : TwoDProfileMonitorClass : cropping/resizing image
Cc: [email protected]
Date: Thu, 28 Jan 2010 17:50:45 -0500
Hi Mark,
Mark Rivers wrote:
Here are a couple of ideas:
- I've got an ImageJ plugin that displays EPICS waveform images from the areaDetector module. It is quite flexible for zooming, line profiles, etc. It uses the native Java implementation of CA.
- If your cameras are supported by areaDetector, then it comes with a very flexible region-of-interest plugin that lets you select regions of the image, reverse axes, bin, etc. The ImageJ viewer responds immediately to such changes in the selected area of the image.
Do you use ImageJ for real-time image display instead of edm : TwoDProfileMonitorClass ?
What I need is to use the format 7 (scalable image) of any IIDC cameras and crop
out a ROI for DAQ during the "real-time display" of the image. so far, I only
used ImageJ for offline data display (e.g. reading image data from a FITS file
instead of DAQ from a camera).
Kate
Sent: Thu 1/28/2010 7:36 PM
To: Kate Feng
We've had similar requests here at SLAC.   We use TwoDProfileMonitorClass
with EDM for our cameras, and are looking for an easier way to select
the region of interest.   We looked briefly into doing a Python/QT camera
viewer with this feature, but haven't had time to get serious about it.
If anyone has a solution for this, we'd be interested in hearing about it.
- Bruce
Kate Feng wrote:
I am using the edm/TwoDProfileMonitorClass for a real-time
image display. Has anyone implemented a point-and-click resizing
tool via the mouse for that class so that one can interactively crop
out a section of the real-time image ?
A simpler implementation would be to have an active cursor
being moved around the real-time image and have a text
message to display the current (x,y) pixel location of the cursor
for users to use it as a reference or an activation point
to define the location of the cropping. Is this already
implemented in the edm video widget ?  Please advise.
Kate
-- Bruce Hill Member Technical Staff SLAC National Accelerator Lab 2575 Sand Hill Road M/S 94 Menlo Park, CA 94025
RE: edm : TwoDProfileMonitorClass : cropping/resizing image Mark Rivers
edm : TwoDProfileMonitorClass : cropping/resizing image Kate Feng
Re: edm : TwoDProfileMonitorClass : cropping/resizing image Bruce Hill
Prev: edm : TwoDProfileMonitorClass : cropping/resizing image Kate Feng
Next: Re: edm : TwoDProfileMonitorClass : cropping/resizing image Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: edm : TwoDProfileMonitorClass : cropping/resizing image Mark Rivers
Next: RE: edm : TwoDProfileMonitorClass : cropping/resizing image Mark Rivers
