1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: do flnk-ed sequences of records get interrupted?
To: Dennis Nicklaus <[email protected]>
Cc: [email protected]
Date: Wed, 03 Feb 2010 10:15:30 -0600
Dennis,
Records in different lock sets can interleave their processing as
task priorities and required resources permit.  You have to assume
records not in your lock set and not otherwise constrained by
mutexes, etc. will process in parallel with you, and that they will
try to find a way to interfere with you.
I don't know enough about StreamDevice's locking to put limits on
what it can accomplish without help from device-level code.
Asyn has support for arranging exclusive access, to a device or port,
that persists until it's rescinded.  See 'blockProcessCallback' in
asynDriver.html.  (I don't know what existing asyn support uses this,
and I haven't written any code that does.)
https://svn.aps.anl.gov/epics/asyn/trunk/documentation/asynDriver.html
Tim
Dennis Nicklaus wrote:
Can someone please explain a few more details about epics processing sequences of FLNK-ed records. Once an flnk-ed sequence begins, can/will another different flnked sequence begin?
Do I have to assume that unrelated (no shared PVs) flnk-ed series can/will run in parallel?
In our case, I have a series of records that implements several reads of a slow serial stream device, and associated other processing. I would like to protect against a user setting a PV that will cause a write to that same device before my series of reads is finished. Do I need to implement some protection? I do know about the statement in the StreadDevice manual that says, "The first out command in the protocol locks the device for exclusive access. That means that no other record can communicate with that device." But I think I'm looking for a different locking across a sequence of records.
Thanks!
Dennis
-- Tim Mooney ([email protected]) (630)252-5417 Beamline Controls & Data Acquisition Group Advanced Photon Source, Argonne National Lab.
do flnk-ed sequences of records get interrupted? Dennis Nicklaus
Prev: Re: do flnk-ed sequences of records get interrupted? Andrew Johnson
Next: Re: CAJ or PV gateway problem? J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: cross compiling base on linux for win32 Martin Konrad
