1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics build with cmake
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Mon, 08 Feb 2010 16:30:17 -0800
Benjamin Franksen wrote:
On Montag, 8. Februar 2010, J. Lewis Muir wrote:
In particular, I would like it if:
1. there was a way to build EPICS without installing it; and if there
   already is, make it the default.  Right now, running "gnumake"
   builds and installs.  To me it should just build.  I should run
   "gnumake install" if I want to install it.
+1
2. I didn't have to edit various files in <EPICS base>/configure or set
   environment variables to tell the EPICS build system where things
   are and what my host hardware architecture is.  It's of course great
   to be able to change these, but I would love good defaults for the
   simple case where I just want it to compile out of the box for the
   current host without having to do a lot of work.
With the exception of setting EPICS_HOST_ARCH this already works for my
favourite platform (kubuntu-linux). Cross-compiling is another matter, of
course...
Cheers
Ben
We just added the following lines in epics base configure/CONFIG_SITE to set EPICS_HOST_ARCH.
Not sure why this isn't the default.
- Bruce
# If EPICS_HOST_ARCH is not set, derive it
ifndef EPICS_HOST_ARCH
EPICS_HOST_ARCH=$(shell $(EPICS_BASE)/startup/EpicsHostArch.pl)
export EPICS_HOST_ARCH
endif
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 94
Menlo Park, CA  94025
epics on launchpad! Davidsaver, Michael
epics build with cmake Davidsaver, Michael
Re: epics build with cmake J. Lewis Muir
Re: epics build with cmake Benjamin Franksen
Prev: Re: epics build with cmake Benjamin Franksen
Next: Re: epics build with cmake Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
