1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Accessing EPICS PV from Allen-Bradley PLC
To: "Elliott Wolin" <[email protected]>, <[email protected]>
Date: Tue, 9 Feb 2010 16:18:19 -0600
Are you already communicating with this PLC from an EPICS IOC?  If so, are you writing to the PLC or only reading from it?
If you are writing to it, then why not have that IOC get the EPICS values and write them to the PLC in addition to the data it is already writing?
Sent: Tue 2/9/2010 4:15 PM
To: [email protected]
Subject: Accessing EPICS PV from Allen-Bradley PLC
For a small and short-lived test setup my A-B ControlLogix PLC needs to
read some EPICS values from another system.  What are my options?
How about using an Ethernet/IP server library?  I.e. write a program
that uses EZCA to poll the EPICS values periodically, then serve them to
the PLC via Ethernet/IP...does this work?
I prefer not to have to purchase anything (e.g KEPserver software), and
just want to use freeware to get past this test.
Any suggestions?
                                Sincerely,
                                        Elliott
 Those raised in a morally relative or neutral environment will hold
                    no truths to be self-evident.
Elliott Wolin
Staff Physicist, Jefferson Lab
12000 Jefferson Ave
Suite 8 MS 12A1
Newport News, VA 23606
757-269-7365
Re: Accessing EPICS PV from Allen-Bradley PLC Elliott Wolin
Prev: Accessing EPICS PV from Allen-Bradley PLC Elliott Wolin
Next: Re: Accessing EPICS PV from Allen-Bradley PLC Elliott Wolin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
