1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MBBO update
To: [email protected]
Date: Thu, 11 Feb 2010 13:27:11 +0100
I'm using mbbo record type that provides 5 values/strings. When mbbo
record is controlled from EDM panel using Radio Box I can set the record
value to desired state.
If the state changes in the underlying software my mbbo record does not
update the value - eg. Radio Box button that was last pressed remains
selected in the EDM panel, while actual state changed.
How can this be done?
Providing mbbi record with same PORT and ADDR as mbbo, I can see that
the state in mbbi record updates as soon as the underlying software
changes the value. But this does not update the mbbo record, though..
Here is the mbbo record:
record(mbbo, "$(DEVICE)SWITCH") {
	field(DTYP, "asynInt32")
	field(OUT, "@asyn($(PORT), 0, 1.0)")
	field(ZRVL, "0")
	field(ONVL, "1")
	field(TWVL, "2")
	field(THVL, "3")
	field(FRVL, "4")
	field(ZRST, "MANUAL")
	field(ONST, "AUTO")
	field(TWST, "AVERAGING")
	field(THST, "COMPENSATING")
	field(FRST, "AVE & COMP")
	field(PINI, "YES")
Best regards,
Hinko
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
RE: MBBO update Mark Rivers
Prev: Intel C Compiler icc on linux? Carl Lionberger
Next: RE: MBBO update Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
