1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer bug?
To: [email protected]
Date: Wed, 24 Feb 2010 12:26:35 +0100
Hi
I am glad I put the question mark in the subject. This is not a bug in the
sequencer but rather in the SNL program. Can you spot it?
Cheers
Ben
On Wednesday 24 February 2010, Benjamin Franksen wrote:
> Hello,
> here is a trivial SNL program I wrote in order to reproduce a
>  misbehaviour that occurs once in a while in one of our production state
>  machines.
> Two state sets communicate via a state variable "x" which is assigned to
>  a bo record and monitored by the program. The master sets x to one, then
>  waits for the slave to reset it to zero. The slave waits for x to become
>  one, then resets it to zero. This all happens in an infinite loop.
> Since there is only one place where x gets set to one (in the master),
>  and one place where it gets reset to zero (in the slave), the assertions
>  in the calls to check() should never fail.
> Your IOC should load this simple database:
>   record(bo,"x") {
> and this sequencer program:
> program SeqTest
> #include <assert.h>
> static int check(x) {
>     assert(x);
>     return 1;
> int done = 0;
> int start = 1;
> int x;
> assign x to "x";
> monitor x;
> ss Master {
>     state idle {
>         when (check(!x)) {
>             printf("Master: work\n");
>         } state work
>     state work {
>         entry {
>             printf("Master: start slave\n");
>             x = start;
>             pvPut(x);
>         when (!x) {
>             printf("Master: slave finished\n");
>         } state idle
> ss Slave {
>     state idle {
>         when (x) {
>             printf("Slave: start work\n");
>         } state work
>     state work {
>         entry {
>             printf("Slave: enter state work\n");
>         when (check(x)) {
>             printf("Slave: work done\n");
>             x = done;
>             pvPut(x);
>         } state idle
> In my tests, the IOC will run for a while but inevitably crash with
> STESTIOC1C: ../seqtest.st:7: test: Assertion `x' failed.
> [1]    8507 abort      ./st.cmd
> This looks like a bug in the sequencer to me. I am testing with
> base-3.14.8.2 and seq-2.0.12.
> (BTW, changing the pvPut calls to SYNC makes no difference.)
> Cheers
> Ben
"...And you know what incurable diseases do: they invite the quacks and
charlatans in, who in this case take the form of Software Engineering
gurus." (Dijkstra, EWD1305)
Sequencer bug? Benjamin Franksen
Prev: Sequencer bug? Benjamin Franksen
Next: caml Patrick Thomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Fwd: Sequencer bug? Benjamin Franksen
