Dear All,
After a long time since the EPICS training, finally I have got time to
learn EPICS.
I installed EPICS base successfully but while installing EDM, I ended
up with some errors, which prevented me moving forward.
In addition to that I am getting plenty of warnings too.
I have the log herewith for your reference:
make -C ./lib install
make[1]: Entering directory `/usr/local/epics/extensions/src/edm/lib'
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. T_A=linux-x86_64 install
make[2]: Entering directory
`/usr/local/epics/extensions/src/edm/lib/O.linux-x86_64'
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE
-Dlinux -D_REENTRANT -O3 -Wall -DSINGLE_THREADED=1
-D__epics__=1 -m64 -g -fPIC -I. -I../O.Common -I. -I..
-I../../../../include/edm/os/Linux -I../../../../include/edm
-I../../../../../base/include/os/Linux -I../../../../../base/include
-I../../../../include -I../../util -I../../lib -I/usr/include
-I/usr/include/X11 ../remFileOpen.cc
../remFileOpen.cc: In function ‘int fileClose(FILE*)’:
../remFileOpen.cc:358: warning: deprecated conversion from string
constant to ‘char*’
../remFileOpen.cc: In function ‘int fileReadable(char*)’:
../remFileOpen.cc:427: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc:429: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc:449: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc: In function ‘void discardParams(char*, int)’:
../remFileOpen.cc:482: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc:484: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc:506: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc: In function ‘void getParams(char*, char*, int)’:
../remFileOpen.cc:528: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc:530: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc:548: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc: In function ‘void reassemble(char*, char*, char*, int)’:
../remFileOpen.cc:570: error: invalid conversion from ‘const char*’ to ‘char*’
../remFileOpen.cc: At global scope:
../remFileOpen.cc:365: warning: ‘int checkForHttp(char*, char*)’
defined but not used
make[2]: *** [remFileOpen.o] Error 1
make[2]: Leaving directory
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/usr/local/epics/extensions/src/edm/lib'
make: *** [lib.install] Error 2
Hope you will help me solving my problem.
Thank you in advance
Hiren Patel
./edmPrint.cc:647: warning: deprecated conversion from string constant to ‘char*’
../edmPrint.cc: In member function ‘int edmPrintClass::openPrintDefFile()’:
../edmPrint.cc:1801: warning: deprecated conversion from string constant to ‘char*’
../edmPrint.cc:1811: warning: deprecated conversion from string constant to ‘char*’
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -m64 -g -fPIC -I. -I../O.Common -I. -I.. -I../../../../include/edm/os/Linux -I../../../../include/edm -I../../../../../base/include/os/Linux -I../../../../../base/include -I../../../../include -I../../util -I../../lib -I/usr/include -I/usr/include/X11 ../tag_pkg.cc
../tag_pkg.cc: In member function ‘int tagClass::decode(char*, char*, int)’:
../tag_pkg.cc:2596: warning: deprecated conversion from string constant to ‘char*’
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -m64 -g -fPIC -I. -I../O.Common -I. -I.. -I../../../../include/edm/os/Linux -I../../../../include/edm -I../../../../../base/include/os/Linux -I../../../../../base/include -I../../../../include -I../../util -I../../lib -I/usr/include -I/usr/include/X11 ../remFileOpen.cc
../remFileOpen.cc:358: warning: deprecated conversion from string constant to ‘char*’
../remFileOpen.cc:365: warning: ‘int checkForHttp(char*, char*)’ defined but not used
make[2]: Leaving directory `/usr/local/epics/extensions/src/edm/lib/O.linux-x86_64'
Problem in installing EDM Hiren Patel
Sequencer bug? Benjamin Franksen
<2010>
2025
2026
<2010>
2025
2026
