1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asyn R4.12 and streamdevice R2.4
To: "TECHTALK Tech-Talk" <[email protected]>
Date: Thu, 25 Feb 2010 13:40:39 -0800
I am trying to build a simple IOC with EPICS R3.14.11, asyn R4.12, and
streamdevice R2.4.  IOC builds without errors, but fails to run.
I also tried EPICS R3.14.9, asyn R4.12, and streamdevice R2.4 with the
same results.
However, when I build the IOC with EPICS R3.14.9, asyn R4.9, and
streamdevice R2.4 the IOC works well.
It appears that streamdevice R2.4 does not work with asyn R4.12.  I have
another IOC which works well with EPICS R3.14.11 and asyn R4.12.  It
does not use streamdevice.
Here are the errors I get:
epicsEnvSet( EPICS_CA_MAX_ARRAY_BYTES,100000)
epicsEnvSet( ETHER, "134.79.64.25")
cd
/afs/slac.stanford.edu/g/testfac/esb/epics/rhel4/R3.14.9/iocTop/tds/prod
dbLoadDatabase("dbd/tds.dbd",0,0)
tds_registerRecordDeviceDriver(pdbbase)
#TDS3000Reboot $(ETHER)
#epicsThreadSleep(60)
vxi11Configure( "L0","134.79.64.25",0,0.0,"gpib0",0,0)
dbLoadRecords( "db/tds.db","P=ESA:TDS:,L=0,A=9,NAME=TDS,PORT=L0")
cd
/iocBoot/sioc-esa-tk01
iocInit()
Starting iocInit
## EPICS R3.14.9-ilc3 $R3-14-9$ $2007/02/05 16:31:45$
## EPICS Base built Nov 11 2009
2010/02/25 13:12:51.149 _main_ ESA:TDS:W_CH1_OFF lockRequest:
pasynManager->queueRequest() failed: port L0 not connected
2010/02/25 13:12:51.149 _main_ ESA:TDS:W_CH1_OFF: Can't start init run
2010/02/25 13:12:51.149 _main_ ESA:TDS:W_CH1_OFF: Record initialization
failed
Bad init_rec return value  PV: ESA:TDS:W_CH1_OFF ao: init_record
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH1_POS lockRequest:
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH1_POS: Can't start init run
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH1_POS: Record initialization
failed
Bad init_rec return value  PV: ESA:TDS:W_CH1_POS ao: init_record
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_OFF lockRequest:
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_OFF: Can't start init run
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_OFF: Record initialization
failed
Bad init_rec return value  PV: ESA:TDS:W_CH2_OFF ao: init_record
2010/02/25 13:12:51.150 _main_ ESA:TDS:W_CH2_POS lockRequest:
Thanks in advance,
Zen
RE: asyn R4.12 and streamdevice R2.4 Mark Rivers
Prev: Re: Fwd: Sequencer bug? Benjamin Franksen
Next: RE: asyn R4.12 and streamdevice R2.4 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS Codeathon before the ITER meeting nick.rees
