Hinko Kocevar wrote:
> Hi Kevin,
> Kevin Anderson wrote:
>> What version of EDM are you using? Also, what versions of Ubuntu and Gentoo are you using?
> edm version is edm-1-12-27.tgz, EPICS base 3.14.10. Gentoo is up to date
> with emerge --world. Ubuntu is Ubuntu 9.10.
>> Did you try recompiling EDM on your x86_64 machine, or were you just using the version you compiled for x86?
> I was recompiling the EPICS + edm on x86_64 machine.
> I don't have the access to the x86_64 machine currently and won't have
> it until March.
> Others suggested to build EPICS_HOST_ARCH=linux-x86_64-debug to provide
> more information and I plan to do so as soon as I get access to that
> x86_64 machine again.
I've gained access to another Gentoo (emerged latest kernel and system)
based x86_64 machine.
This time I've compiled the EPICS for EPICS_HOST_ARCH=linux-x86_64-debug
target. The EDM fails as before, but now I have some more info:
*** glibc detected *** edm: double free or corruption (!prev):
0x000000000217f050 ***
======= Backtrace: =========
/lib/libc.so.6[0x7eff08df5808]
/lib/libc.so.6(cfree+0x6c)[0x7eff08dfa24c]
/home/support/epics/install/lib/linux-x86_64-debug/libEdmBase.so(_ZN12xyGraphClass10deactivateEi+0x537)[0x7eff0bb1b12f]
/home/support/epics/install/lib/linux-x86_64-debug/libcfcaa62e-8199-11d3-a77f-00104b8742df.so(_ZN18activeGraphicClass10deactivateEiPi+0x2c)[0x7eff0b6c1726]
/home/support/epics/install/lib/linux-x86_64-debug/libcfcaa62e-8199-11d3-a77f-00104b8742df.so(_ZN17activeWindowClass12returnToEditEi+0x422)[0x7eff0b68c068]
/home/support/epics/install/lib/linux-x86_64-debug/libcfcaa62e-8199-11d3-a77f-00104b8742df.so(_ZN17activeWindowClass24executeFromDeferredQueueEv+0x36b)[0x7eff0b6904b5]
/home/support/epics/install/lib/linux-x86_64-debug/libcfcaa62e-8199-11d3-a77f-00104b8742df.so(_ZN15appContextClass29processDeferredExecutionQueueEv+0x11a)[0x7eff0b66e036]
/home/support/epics/install/lib/linux-x86_64-debug/libcfcaa62e-8199-11d3-a77f-00104b8742df.so(_ZN15appContextClass15applicationLoopEv+0xc1b)[0x7eff0b670de7]
edm[0x40832e]
/lib/libc.so.6(__libc_start_main+0xe6)[0x7eff08da0a26]
edm(_ZNSt8ios_base4InitD1Ev+0x39)[0x4030b9]
======= Memory map: ========
00400000-0040b000 r-xp 00000000 08:03 7259433
/home/support/epics/install/bin/linux-x86_64-debug/edm
0060a000-0060b000 r--p 0000a000 08:03 7259433
0060b000-0060c000 rw-p 0000b000 08:03 7259433
0060c000-00619000 rw-p 00000000 00:00 0
01f39000-02206000 rw-p 00000000 00:00 0
[heap]
7eff00000000-7eff00021000 rw-p 00000000 00:00 0
7eff00021000-7eff04000000 ---p 00000000 00:00 0
7eff04a2e000-7eff04aaf000 rw-p 00000000 00:00 0
7eff04aaf000-7eff04ab0000 ---p 00000000 00:00 0
7eff04ab0000-7eff04af0000 rw-p 00000000 00:00 0
7eff04af0000-7eff04b03000 r-xp 00000000 08:03 9405820
/lib64/libresolv-2.10.1.so
7eff04b03000-7eff04d02000 ---p 00013000 08:03 9405820
7eff04d02000-7eff04d03000 r--p 00012000 08:03 9405820
7eff04d03000-7eff04d04000 rw-p 00013000 08:03 9405820
7eff04d04000-7eff04d06000 rw-p 00000000 00:00 0
7eff04d06000-7eff04d0b000 r-xp 00000000 08:03 9405825
/lib64/libnss_dns-2.10.1.so
7eff04d0b000-7eff04f0a000 ---p 00005000 08:03 9405825
7eff04f0a000-7eff04f0b000 r--p 00004000 08:03 9405825
7eff04f0b000-7eff04f0c000 rw-p 00005000 08:03 9405825
7eff04f0c000-7eff04f11000 r-xp 00000000 08:03 8986723
/usr/lib64/libXfixes.so.3.1.0
7eff04f11000-7eff05110000 ---p 00005000 08:03 8986723
7eff05110000-7eff05111000 r--p 00004000 08:03 8986723
7eff05111000-7eff05112000 rw-p 00005000 08:03 8986723
7eff05112000-7eff0511b000 r-xp 00000000 08:03 8986733
/usr/lib64/libXrender.so.1.3.0
7eff0511b000-7eff0531a000 ---p 00009000 08:03 8986733
7eff0531a000-7eff0531b000 r--p 00008000 08:03 8986733
7eff0531b000-7eff0531c000 rw-p 00009000 08:03 8986733
7eff0531c000-7eff05325000 r-xp 00000000 08:03 8986765
/usr/lib64/libXcursor.so.1.0.2
7eff05325000-7eff05524000 ---p 00009000 08:03 8986765
7eff05524000-7eff05525000 r--p 00008000 08:03 8986765
7eff05525000-7eff05526000 rw-p 00009000 08:03 8986765
7eff05526000-7eff0552e000 r-xp 00000000 08:03 8914303
/usr/lib64/libgif.so.4.1.6
7eff0552e000-7eff0572d000 ---p 00008000 08:03 8914303
7eff0572d000-7eff0572e000 r--p 00007000 08:03 8914303
7eff0572e000-7eff0572f000 rw-p 00008000 08:03 8914303
7eff0572f000-7eff0573f000 r-xp 00000000 08:03 7259435
/home/support/epics/install/lib/linux-x86_64-debug/libcf322683-513e-4570-a44b-7cdd7cae0de5.so
7eff0573f000-7eff0593f000 ---p 00010000 08:03 7259435
7eff0593f000-7eff05940000 r--p 00010000 08:03 7259435
7eff05940000-7eff05941000 rw-p 00011000 08:03 7259435
7eff05941000-7eff05951000 r-xp 00000000 08:03 7259442
/home/support/epics/install/lib/linux-x86_64-debug/libTwoDProfileMonitor.so
7eff05951000-7eff05b51000 ---p 00010000 08:03 7259442
7eff05b51000-7eff05b52000 r--p 00010000 08:03 7259442
7eff05b52000-7eff05b53000 rw-p 00011000 08:03 7259442
7eff05b53000-7eff05b93000 r-xp 00000000 08:03 7259438
/home/support/epics/install/lib/linux-x86_64-debug/libPV.so
7eff05b93000-7eff05d93000 ---p 00040000 08:03 7259438
/home/support/epics/install/lib/linux-x86_64-debug/libPV.so../../../edm.sh:
line 40: 23925 Aborted edm $@
+ exit 134
Thank you!
Hinko Kocevar
Technical support software engineer
Instrumentation Technologies
Velika pot 22, SI-5250 Solkan - Slovenia
T:+386 5 3352600, F:+386 5 3352601
mailto: [email protected]
http://www.i-tech.si - When your users demand stability
The information transmitted is intended solely for the addressee and may
contain confidential and/or privileged information. Any review, retention,
disclosure or other use by persons other than the intended recipient is
prohibited. If you received this in error, please notify the sender and
delete all copies.
- Re: EDM crashing Hinko Kocevar
- RE: EDM crashing Kevin Anderson
RE: compile error with medm 3.1.3 on fedora 10 Hitesh
Re: compile error with medm 3.1.3 on fedora 10 Geoff Savage
<2010>
2025
2026
<2010>
2025
2026
