1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Building StreamDevice 2-4 / SynApps / Win32
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 11 Mar 2010 22:37:12 -0600
On 3/11/10 8:16 PM, John Dobbins wrote:
> J. Lewis Muir wrote:
>> On 3/11/10 6:04 PM, Mark Rivers wrote:
>>> I'm stumped.
>>> -----Original Message-----
>>> From: John Dobbins [mailto:[email protected]] Sent: Thursday,
>>> March 11, 2010 3:42 PM
>>> To: Mark Rivers; EPICS Tech-Talk
>>> Subject: RE: Building StreamDevice 2-4 / SynApps / Win32
>>> Mark,
>>> FYI, if I create stream.dbd to look like yours and continue make I
>>> encounter the same problem when it gets around to making target
>>> streamReferences which has similar syntax.
>>> John
>> Hi, John.
>> What about your version of make -- what implementation and version are
>> you using?
>> Lewis
> Lewis,
> I am using make from GnuWin32, version is 3.81
> http://gnuwin32.sourceforge.net/packages.html
> This definitely appears like a make problem to me - but not sure what
> other version to try.
> Mark Rivers is using a version from cygwin - I might try that tomorrow -
> other suggestions?
Hi, John.
I guess there's also MinGW that you could try.
I looked more closely at your error output where it says "r was
unexpected at this time" and at the Makefile target for building
stream.dbd which you included in a previous email.  I see that its first
command line is:
  @for r in $(RECORDS); \
I think this for loop will get executed in the shell.  By default, that
should be /bin/sh on a Unix-like system; I don't know what it defaults
to for GnuWin32.  But it can be override with the SHELL variable.  Maybe
you've got the wrong shell being used or your shell is broken.  Can you
find out what shell is being used?  If not a Bourne shell, that's a
problem.  If a Bourne shell, what one and what version?  Does a simple
shell script using a for loop work with the shell being used by make?
For example, assuming the shell used by make is /bin/sh:
  $ cat for-loop-test.sh
  for r in 1 2 3; do
    echo $r
  done
  $ /bin/sh for-loop-test.sh
  1
  2
  3
Lewis
RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
RE: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Re: Building StreamDevice 2-4 / SynApps / Win32 J. Lewis Muir
Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
Prev: RE: compile error with medm 3.1.3 on fedora 10 Hitesh
Next: RE: Building StreamDevice 2-4 / SynApps / Win32 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building StreamDevice 2-4 / SynApps / Win32 John Dobbins
