1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: JCA type conversion
To: [email protected]
Date: Thu, 01 Apr 2010 09:36:09 -0500
On 4/1/10 6:58 AM, rolf wrote:
> I am trying to work with Java Channel access (JCA 2.3.2  and CAJ
> 1.1.5b). I may have blinders on, but the only documentation I can find
> is the APS tutorial and the JCA javadoc (for JCA 2.1.2). If there is
> anything else, could someone please point me to it.
> My specific problem:
> I have a MonitorListener, which delivers a MonitorEvent on a PV value
> change.
> The MonitorEvent gives me DBR, from which I want to get the new value as
> a String.
> My code looks like this:
> DBR dbr = evt.getDBR();
> DBR dbr2 = dbr.convert(DBRType.CTRL_STRING);
> String[] s = ((DBRString) dbr2).getStringValue();
> s[0] contains the correct value for all DBR types, with the exception of
> enumerated types, where it has an empty string.
> What am I doing wrong?
Hi, Rolf.
I've never done what you're trying to do, but have you seen the
following Tech-Talk post?
  http://www.aps.anl.gov/epics/tech-talk/2006/msg01221.php
Perhaps you need to use DBRType.LABELS_ENUM?
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT
JCA type conversion rolf
Prev: JCA type conversion rolf
Next: create arrays in EDM Jovan Loncar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: JCA type conversion Simon Ebner
