Hi Allen,
On Wednesday 07 April 2010 15:57:28 Al Honey wrote:
> > I don't think the CA client
> > interface changed too much between 3.13 and 3.14.
> Okay, that is good :)
> I will start researching the differences.
I would suggest starting by just trying to compile your code against 3.14.11.
I believe the CA Reference manual no longer documents all of the deprecated
API calls but the code still supports most if not all of them. You will need
to make changes if you have multiple threads making CA calls, but for many
single-threaded client applications I believe a recompile can be sufficient.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- cac_select_io Segmentation fault Al Honey
- Re: cac_select_io Segmentation fault Ralph Lange
- RE: cac_select_io Segmentation fault Al Honey
RE: cac_select_io Segmentation fault Jeff Hill
<2010>
2025
2026
<2010>
2025
2026
