I saw the same problem on RHEL5. I just installed a 32bit version in our
64bit path for now until it is fixed.
--Bob
Ramu Denduluri wrote:
Hi All,
Following are the two cases for which Striptool is getting crashed.
1) Striptool version 2.5.10.0 with Epics Base version 3.14.11. On the
striptool graph window, right click and select toggle buttons option. If
you do it one or more times, the strip toll is getting crashed.
Following is the crash message.
/.../linux-x86_64/engMenu_startStripTool: line 76: 13044 Segmentation
fault StripTool ${configurationDir}/${fileName}
2) Striptool version 2.5.12.0 with Epics Base version 3.14.11. On the
striptool graph window, right click and select control option and
immediately the striptool crashes. Following are the log messages.
==== StripTool Xt Warning Handler ====
warning: Axis: minVal is greater than or equal to maxVal
Segmentation fault
If there are any solutions for the above problems, please let me know.
Best Regards,
Ramu
- Striptool crashes for Fedora 11 64 bit version... Ramu Denduluri
MAXv problem Davidsaver, Michael
Re: MAXv problem Ron Sluiter
<2010>
2025
2026
MEDM Panels disappeared frequently on Fedora Code 8 32 bit version... Ramu Denduluri
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
