By far the best solution is indeed to compile a 32-bit version (one way or another). It will run perfectly on a 64-bit machine.
I was poking at this a while ago, and managed to fix the crash on toggling buttons, but I never found a way to correct the gross mishandling of the axes.
http://www.aps.anl.gov/epics/tech-talk/2009/msg01226.php
Unfortunately it seems that further development of this tool is thoroughly stalled.
-K
> 1) Striptool version 2.5.10.0 with Epics Base version 3.14.11. On the striptool graph window, right click and select toggle buttons option. If you do it one or more times, the strip toll is getting crashed. Following is the crash message.
> /.../linux-x86_64/engMenu_startStripTool: line 76: 13044 Segmentation fault StripTool ${configurationDir}/${fileName}
> 2) Striptool version 2.5.12.0 with Epics Base version 3.14.11. On the striptool graph window, right click and select control option and immediately the striptool crashes. Following are the log messages.
> ==== StripTool Xt Warning Handler ====
> warning: Axis: minVal is greater than or equal to maxVal
> Segmentation fault
> If there are any solutions for the above problems, please let me know.
> Best Regards,
> Ramu
- Re: Striptool crashes for Fedora 11 64 bit version... Janet Anderson
gateway won't set "busy" PV type properly Dennis Nicklaus
EDM's -ro option and running arbitrary scripts w/ in our case caputs Carl Schumann
<2010>
2025
2026
Re: MEDM Panels disappeared frequently on Fedora Code 8 32 bit version... Robert Soliday
<2010>
2025
2026
