1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: USB ADC/DACs
To: "Pawel Kowalski - BiRa Systems Inc." <[email protected]>
Cc: [email protected]
Date: Wed, 5 May 2010 09:09:48 -0700
I'm surprised that you're hearing more requests for USB connections than for ethernet.  The latter allows for much longer connections and is better supported by EPICS/ASYN.
In any case, a small PLC sounds like it would take care of this just fine.
How about something like (only 0 to 5V, but perhaps that's good enough):
Adding an FTDI USB/Serial adapter adds about $20.00
There are small PLCs in this price range with Ethernet, too.
On May 5, 2010, at 8:35 AM, Pawel Kowalski - BiRa Systems Inc. wrote:
Hello,
Based on feedback I got at the beam and instrumentation workshop this week I am trying to come up with a simple and cheap design to control analog power supplies. Nothing is set in stone and I just want to find what we would need to get to make this controller. I am trying to find a DAC/ADC that can be connected using USB to a soft-ioc running linux. I don’t need a lot of channels, 1 analog in and 1 analog out would be fine (2 of each would be preferred) and having a couple digital in/digital out channels would be nice too (but not required). The voltage will be 0-10V (if a bipolar DAC/ADC is available that would be great). I would probably need to have at least 16 bits of resolution on the DAC/ADC. The speed doesn’t have to be terribly fast from what I gathered. Cost is an issue (trying to stay under $200) but if something is out there that costs more than this I would like to take a look at it anyway.
I wonder if anyone in the epics community has worked with such a device and if they have epics drivers available. If epics drivers aren’t available I can probably configure something myself using ASYN if someone can point me to a good reliable device. Any suggestions would be greatly appreciated, thank you.
Pawel Kowalski
BiRa Systems Inc.
Phone:                   505-881-8887
Fax:                       505-888-0651
Address:                2410 Midtown PL NE
STE A
Albuquerque NM 87107 USA
Eric Norum
[email protected]
RE: USB ADC/DACs Pawel Kowalski - BiRa Systems Inc.
Prev: USB ADC/DACs Pawel Kowalski - BiRa Systems Inc.
Next: RE: USB ADC/DACs Pawel Kowalski - BiRa Systems Inc.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
