1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: No monitor refresh
To: EPICS Tech Talk <[email protected]>
Date: Tue, 11 May 2010 09:21:29 -0400
Hello Hinko,
what EPICS versions are you using for client and IOC?
Can you show a dump (dbpr <name>, 4) of the record that you are
connecting to?
What field of that record are you connecting to?
Ralph
On Tue 11 May 2010 6:26:48 Hinko Kocevar wrote:
Hi all,
I'm experiencing some strange behavior when using camonitor against an
EPICS IOC.
For some reason a CA_PROTO_EVENT_ADD response from IOC to CA client does
not arrive, or arrives several minutes later after the PV value has
changed. Note that first CA_PROTO_EVENT_ADD response is seen always,
only latter CA_PROTO_EVENT_ADD responses do not arrive (or arrive late)?!
This behavior is not seen always - sometimes the IOC would promptly
respond with CA_PROTO_EVENT_ADD response when needed.
I can see the CA_PROTO_ECHO requests/responses fine on the same
camonitor channel link, only CA_PROTO_EVENT_ADD response is not seen.
Inspecting the IOC I can see that the value did change (on lower levels)
and caput response is also valid - updated with new value.
I've ruled out the network problems, since the issue is raised even when
using cross-over cable to communicate with the IOC. Actually even I
update the value in the IOC shell, the camonitor is not refreshed!!
Has someone experienced something similar?
Are there some conditions that need to fulfilled in order for IOC to
send a subsequent CA_PROTO_EVENT_ADD response(s)?
TIA & HAND,
Hinko
Re: No monitor refresh Hinko Kocevar
Prev: RE: AutoSaveRestore of the motor position Mark Rivers
Next: Re: No monitor refresh Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: No monitor refresh Hinko Kocevar
