1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: No monitor refresh
To: "'Hinko Kocevar'" <[email protected]>, "'EPICS Tech-Talk'" <[email protected]>
Date: Tue, 11 May 2010 08:45:32 -0600
Hello Hinko,
You mention that a caput updates the value in the IOC but the subscription update does not arrive or is late arriving. That might happen if 100% of the IOC's CPU is being consumed by threads running at higher priorities than the CA server. What type of record and field is the camonitor attached to?
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Hinko Kocevar
> Sent: Tuesday, May 11, 2010 4:27 AM
> To: EPICS Tech-Talk
> Subject: No monitor refresh
> Hi all,
> I'm experiencing some strange behavior when using camonitor against an
> EPICS IOC.
> For some reason a CA_PROTO_EVENT_ADD response from IOC to CA client does
> not arrive, or arrives several minutes later after the PV value has
> changed. Note that first CA_PROTO_EVENT_ADD response is seen always,
> only latter CA_PROTO_EVENT_ADD responses do not arrive (or arrive late)?!
> This behavior is not seen always - sometimes the IOC would promptly
> respond with CA_PROTO_EVENT_ADD response when needed.
> I can see the CA_PROTO_ECHO requests/responses fine on the same
> camonitor channel link, only CA_PROTO_EVENT_ADD response is not seen.
> Inspecting the IOC I can see that the value did change (on lower levels)
> and caput response is also valid - updated with new value.
> I've ruled out the network problems, since the issue is raised even when
> using cross-over cable to communicate with the IOC. Actually even I
> update the value in the IOC shell, the camonitor is not refreshed!!
> Has someone experienced something similar?
> Are there some conditions that need to fulfilled in order for IOC to
> send a subsequent CA_PROTO_EVENT_ADD response(s)?
> TIA & HAND,
> Hinko
> Hinko Kocevar
> Technical support software engineer
> Instrumentation Technologies
> Velika pot 22, SI-5250 Solkan - Slovenia
> T:+386 5 3352600, F:+386 5 3352601
> mailto: [email protected]
> http://www.i-tech.si - When your users demand stability
> The information transmitted is intended solely for the addressee and may
> contain confidential and/or privileged information. Any review,
> retention,
> disclosure or other use by persons other than the intended recipient is
> prohibited. If you received this in error, please notify the sender and
> delete all copies.
Re: No monitor refresh Hinko Kocevar
Prev: Re: No monitor refresh Hinko Kocevar
Next: Re: No monitor refresh Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: No monitor refresh Hinko Kocevar
