1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Oddity with mbbo strings
To: "[email protected]" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 11 May 2010 16:59:34 -0700
Hi Emmanuel,
I'm unable to reproduce this problem on epics 3.14.8.2, linux-x86 (RHEL4, 32 bit).  Perhaps someone else can.  It would be helpful if you provide the version of EPICS base, the OS, and dbpr of both records (level 4 or 5).
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of [email protected]
> Sent: Tuesday, May 11, 2010 4:19 PM
> To: EPICS tech-talk
> Subject: Oddity with mbbo strings
> I am trying to pass the value of a stringout to a ZRST of a mbbo record.
> I set the OUT field of the stringout to point to that field in the mbbo.
> To my surprise the end of string \0 is not passed.
> As a result if the new string written on that field is shorter than the previous one, well ...
> the resulting value is a superposition of the 2 strings.
> That is
> "LONG_STRING" -> ZRST   -- works as expected
> "SHORT" -> ZRST         -- stored value os "SHORTSTRING"
> Is there a work around?
> can sCaclout help?
> Emmanuel
Oddity with mbbo strings emmanuel_mayssat
Prev: Oddity with mbbo strings emmanuel_mayssat
Next: 答复: AutoSaveRestore of the motor position 张招红
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: MAXv vs XPS liuping
