Andrew Johnson wrote:
Hi Carl,
On Wednesday 12 May 2010 11:02:59 Carl Schumann wrote:
We are updating to the latest EPICS gateway, but have found compilation
issues in tsHash.h:
../tsHash.h: At global scope:
../tsHash.h:27: error: ISO C++ forbids declaration of 'gphPvt' with no
type
../tsHash.h:27: error: expected ';' before '*' token
Which version of Base are you building this with? You *have* to use R3.14.11
(or later, but we haven't released any since), which you would want anyway
since that has essential bug fixes in CAS and I believe even an API change.
- Andrew
We intended to be building with R3.14.11 but in fact were not. Now that
we have that corrected it does in deed build. Thanks.
- Gateway compilation issue in tsHash.h Carl Schumann
- Re: Gateway compilation issue in tsHash.h Andrew Johnson
Re: Looking for runcontrol record sources Claude Saunders
Re: No monitor refresh Hinko Kocevar
<2010>
2025
2026
Looking for runcontrol record sources emmanuel_mayssat
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
