1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics debian repository update
To: [email protected]
Date: Thu, 20 May 2010 21:14:26 +0200
On Donnerstag, 20. Mai 2010, Michael Davidsaver wrote:
> On 05/19/10 15:26, Benjamin Franksen wrote:
> > On Mittwoch, 19. Mai 2010, Davidsaver, Michael wrote:
> >> The difficultly is cross compiling for RTEMS.  I'm not sure if it will
> >> work out in the long term, but I have had positive feedback from the
> >> few people who have used it.
> > It is great mystery to me how you could build an EPICS package at all.
> The usual way, lots of trial, and lots of error :)
> > What about all the other cross-compiler targets and their specific
> > configuration?
> While I've had many frustrations with it, I must say that this is were
> the Base build system helped me.  Mostly this just worked.
How?
> Of course I
> only cross-build RTEMS, not other host targets.  There is much less
> chance of shared library dependency problems when you don't have shared
> libraries!
I don't understand. This is from base-3.14.11/configure/CONFIG_SITE:
#  The cross-compiler architectures to build EPICS for
#  Currently Supporting:
#       linux-386               (linux-x86 host)
#       linux-486               (linux-x86 host)
#       linux-586               (linux-x86 host)
#       linux-686               (linux-x86 host)
#       linux-arm
#       linux-arm_eb
#       linux-arm_el
#       linux-athlon            (linux-x86 host)
#       linux-cris              (Axis GNU crosscompiler on linux-x86 host)
#       linux-cris_v10          (Axis GNU crosscompiler on linux-x86 host)
#       linux-cris_v32          (Axis GNU crosscompiler on linux-x86 host)
#       linux-xscale_be
#       vxWorks-486
#       vxWorks-68040
#       vxWorks-68040lc
#       vxWorks-68060
#       vxWorks-pentium
#       vxWorks-ppc603
#       vxWorks-ppc603_long
#       vxWorks-ppc604
#       vxWorks-ppc604_long
#       vxWorks-ppc604_altivec
#       vxWorks-mpc8540
#       RTEMS-at91rm9200ek
#       RTEMS-beatnik
#       RTEMS-gen68360
#       RTEMS-mcp750
#       RTEMS-mvme167
#       RTEMS-mvme2100
#       RTEMS-mvme3100
#       RTEMS-mvme5500
#       RTEMS-pc386
#       RTEMS-psim
#       RTEMS-uC5282
# Definitions of CROSS_COMPILER_TARGET_ARCHS in
# configure/os/CONFIG_SITE.<host>.Common files will
# override
CROSS_COMPILER_TARGET_ARCHS=
How does the debian package know which of them I (a) have installed, and (b)
want to build EPICS against?
One solution I could imagine is to have an epics-base package, and then lots
of dependent packages for each possible cross target, like e.g.
epics-base-vxworks-pentium, etc. Of course these would have to depend on
properly packaged (or at least, installed) target cross compilers.
Cheers
Ben
epics debian repository update Davidsaver, Michael
Re: epics debian repository update Benjamin Franksen
Re: epics debian repository update Michael Davidsaver
Prev: Re: epics debian repository update J. Lewis Muir
Next: asyn R4-13-1 available Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epics debian repository update Michael Davidsaver
Next: Re: epics debian repository update Andrew Johnson
