1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Race conditions in SNL programs
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Thu, 20 May 2010 21:16:27 -0500
Hi Ben
On Thursday 20 May 2010 17:53:04 Benjamin Franksen wrote:
> This bug must have been in the sequencer for a long, long time, probably
> right from the beginning.
I'm not convinced it's quite as bad as you think; I suspect it derives from
R3.14.x when Jeff introduced the ca_enable_preemptive_callback option.  Before
this time the CA library never got a chance to process network messages unless
you called it using ca_pend_event() or ca_pend_io() so the callbacks would
only run when the thread was inside the CA library.
Hmm, that doesn't necessarily work with multiple state sets though, I wonder
if CA supported sharing CA contexts back then?  I think Jeff may have to chime
in on that one, but he may already be on his way to Diamond for the Codeathon
next week so don't hold your breath.
In the short term you should be able to fix this for single-SS programs by
changing the argument to the ca_context_create() call (in pvCa.cc) to disable
preemptive callbacks; I'm not sure if you will have to make any other changes,
but you should be able to look back through the history to see what else was
done at the same time that option was turned on.  Longer term the ball is in
your court I guess...
- Andrew
PS: I usually assume that everyone who subscribes to core-talk also reads
tech-talk, so there's probably no need to post to both.
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Race conditions in SNL programs Benjamin Franksen
Prev: Re: genSub to aSub conversion Andrew Johnson
Next: Re: Race conditions in SNL programs Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Race conditions in SNL programs Chestnut, Ronald P.
