1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PV's element count differs though CA gateway
To: [email protected], Dehong Zhang <[email protected]>
Cc: Salah J Chaurize <[email protected]>, "Denise S. Finstrom" <[email protected]>
Date: Fri, 21 May 2010 14:14:34 -0500
Tech-talk, Dehong Zhang,
We have a client application which attempts to access a PV's elements 0 to 999 . This application is run on two sets of machines. One set must go through an EPICS gateway to access the PV. The other set does not do so. The application does not run properly when going through the gateway because of an out-of-bounds error at element 940. It is able to access elements all they way up to 999 without issue when there is no gateway involved.
We were able to track this issue down to a difference in the element count reported by the originating IOC vs. the gateway using cainfo. For the gateway case cainfo reports element count 940, but for the non-gateway case cainfo reports 1000. Using EPICS_CA_ADDR_LIST we were able to reproduce both element counts on a single machine depending on whether the gateway or the originating IOC responded. The result is attached.
Me and my co-workers find this result unexpected and are not sure how to fix it. Any help would be appreciated please. Thanks for your time.
Sincerely,
Carl Schumann
P.S.: for my co-worker Dehong owner of the hins_ws.py:
The client is hins_ws.py. The PV is PD_LEBT:Inst:WS1.RST1. It is the out-of-bound error that prevents the Save Result button from generating a file. Do have any insight about what might be going on here? Thanks.
clx22$ export EPICS_CA_ADDR_LIST=131.225.143.59
clx22$ cainfo PD_LEBT:Inst:WS1.RST1
CA.Client.Exception...............................................
    Warning: "Identical process variable names on multiple servers"
    Context: "Channel: "PD_LEBT:Inst:WS1.RST1", Connecting to: 131.225.143.59:5064, Ignored: cag-clx-2.fnal.gov:5064"
    Source File: ../cac.cpp line 1209
    Current Time: Fri May 21 2010 13:20:42.301346264
    State:         connected
    Host:          hinst1.fnal.gov:5064
    Access:        read, write
    Data type:     DBR_FLOAT (native: DBF_FLOAT)
    Element count: 1000
    State:         connected
    Host:          cag-clx-2.fnal.gov:5064
    Access:        read, write
    Element count: 940
    Context: "Channel: "PD_LEBT:Inst:WS1.RST1", Connecting to: 131.225.120.203:5064, Ignored: hinst1.fnal.gov:5064"
    Current Time: Fri May 21 2010 13:25:01.625878952
clx22$
RE: PV's element count differs though CA gateway Jeff Hill
Prev: Re: genSub to aSub conversion emmanuel_mayssat
Next: RE: PV's element count differs though CA gateway Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: genSub to aSub conversion Andrew Johnson
