| I don't think that you'll have much luck porting EPICS to a 16-bit machine. I'm curious as to why you'd want to use such an old architecture. On May 25, 2010, at 12:43 PM, tanushyam bhattacharjee wrote: nobody has commented on this. Is it possible to implement all EPICS functionality if change the osi library as per need? tanushyam
--- On Tue, 25/5/10, tanushyam bhattacharjee <[email protected]> wrote:
From: tanushyam bhattacharjee <[email protected]> Subject: running IOC on 80188 processor running DOS To: [email protected] Date: Tuesday, 25 May, 2010, 3:38 PM
Is it possible to build and
IOC on 80188 processor running DOS? I am planning to put DOS RT kernel above DOS and build the IOC. 1.What are the steps I should follow? 2.Can I use the available base source files directly to build the IOC?
Tanushyam
- Re: running IOC on 80188 processor running DOS tanushyam bhattacharjee
Re: running IOC on 80188 processor running DOS Ralph Lange
iPhone port Pelaia II, Tom
<2010>
2025
2026
Re: running IOC on 80188 processor running DOS Eric Norum
labCA and EPICS_CA_MAX_ARRAY_BYTES John Dobbins
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
