1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: a waveform record question
To: [email protected]
Cc: fenggangbian <[email protected]>
Date: Thu, 27 May 2010 07:44:47 -0500
On Wednesday 26 May 2010 09:33:33 fenggangbian wrote:
> Hi,
>    Now I am working a program using LabView talk to EPICS by shared
> memeory. LabView create a local softIOC ,firstly LabView talk to the soft
> ioc and use the softioc to connect other outside ioc. I may already use
> LabView to connect soft IOC. I encounter a question that how to write a
> waveform PV in soft IOC to other waveform PV in anther IOC. The support
> record of array in the soft IOC only have subArray record and waveform
> record. Such as aao etc record don't support.
The waveform record has soft support using the INP link, so your second IOC
could read the waveform data from the soft IOC.  If you mark the input link as
CP it will process that record automatically whenever the source record posts
a monitor on value update.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
RE: a waveform record question Mark Rivers
a waveform record question fenggangbian
Prev: Epics 3.14.8: faulty registrar statement in dbd causes memPartAlloc error on vxWorks Goetz Pfeiffer
Next: Re: Epics 3.14.8: faulty registrar statement in dbd causes memPartAlloc error on vxWorks Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: a waveform record question fenggangbian
Next: RE: a waveform record question Mark Rivers
