I'm currently trying to not just talk to (that part was easy) but also get replies back from a device that responds in a somewhat awkward way. On an xterm it looks like this: The command is S (with no <cr> or <lf>) and the response is: Time,1 (0.5),2 (0.7),3 (1.0),4 (2.0),5 (3.0),6 (5.0),7 (7.0),8 (10.0),Alarms,Flow(lpm),AT(C),BP(mmHg),RH(%) 176502,302,119,66,23,6,2,2,0,12,1.6,27.4,348.6,51 where the first line (which ends in RH(%)) comes back immediately and the second line after a sampling period that can be specified. If I do the same from an IOC I get the following (with drvAscii debug output included but edited to reassemble the mixed up buffers): drvAscii(2) => S[ a] filename="../drvAscii.c" line number=4057 S_errno_EINTR : [/pty/dustm.M] lost sem - recovering filename="../drvAscii.c" line number=4074 S_errno_EINTR : [/pty/dustm.M] lost msg sync - discarding response filename="../drvAscii.c" line number=4074 S_errno_EINTR : [/pty/dustm.M] lost msg sync - discarding response filename="../drvAscii.c" line number=4074 S_errno_EINTR : [/pty/dustm.M] lost msg sync - discarding response filename="../drvAscii.c" line number=4074 S_errno_EINTR : [/pty/dustm.M] lost msg sync - discarding response filename="../drvAscii.c" line number=4074 S_errno_EINTR : [/pty/dustm.M] lost msg sync - discarding response filename="../drvAscii.c" line number=4074 S_errno_EINTR : [/pty/dustm.M] lost msg sync - discarding response filename="../drvAscii.c" line number=4074 S_errno_EINTR : [/pty/dustm.M] lost msg sync - discarding response drvAscii(5) <= >S [ d][ a] drvAscii(110) <=Time,1 (0.5),2 (0.7),3 (1.0),4 (2.0),5 (3.0),6 (5.0),7 (7.0),8 (10.0),Alarms,Flow(lpm),AT(C),BP(mmHg),RH(%)[ d][ a] drvAscii(3) <= [ d][ a] drvAscii(3) <= [ d][ a] drvAscii(51) <= >183771,213,72,28,7,2,1,1,1,12,1.6,28.6,343.2,45[ d][ a] drvAscii(2) => Q[ a] drvAscii(4) <= Q[ d][ a] drvAscii(4) <= >[ d][ a] drvAscii(3) <= [ d][ a] I tried the %nT (suggested by somebody in the office) format but never managed to get past the line that's too long. This is on EPICS 3.13.8 and I think we're using drvAscii 2.3.
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
