Subject: |
Re: streamDevice trick for in with or without value |
Dirk Zimoch <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Fri, 04 Jun 2010 13:34:24 +0200 |
Hello Emmanuel,
I am sorry but at the moment I do not have any "number or nothing" matching.
But there is still hope: Write your own format converter!
Start with a copy of StdLongConverter from StreamFormatConverter.cc,
modify it to set value to 0 on failure and return 0. Then register it
with any unused conversion character. In parse() don't use
info.append(fmt.conv), use info.append('d') instead.
You are not the first one with such a problem.
Maybe I should extend the syntax to something like %?d to return 0 (and
succeed) if nothing can be read. Let me see if I can do that quickly.
Dirk
[email protected] wrote:
I am using stream.
I have a serial device whose query/reply follow thisi pattern:
out "get value"
in "F: W: IK:"
If values are 0
If values are not 0, I have
out "get value"
in "F: 12 W: IK:" <- value is 12
Is there a way to make this value conditional in stream?
With the current protocol, I have a mismatch and my record becomes invalid
(and stop processing).
1/ How can I make the protocol work?
2/ Assuming that there is a mismatch, how can I restore my record to "valid" status?
thanks,
- streamDevice trick for in with or without value emmanuel_mayssat
EPICS support for Mass Spectrometers nick.rees
bspExt.h nick.rees
<2010>
2025
2026
Re: streamDevice trick for in with or without value emmanuel_mayssat
Medipix2 detector matthew.pearson
<2010>
2025
2026
