1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA Lab - New interface between LabVIEW? and EPICS
To: [email protected]
Date: Tue, 08 Jun 2010 06:08:39 +0100
What is "CA Lab"?
"CA Lab" is a user-friendly, lightweight and high performance interface between LabVIEW? and EPICS.
This project uses proven EPICS BASE libraries (V3.14.11), a "CA Lab"-library and 3 "CA Lab"-VIs.
Why another EPICS<->LabVIEW? interface?
LabVIEW? needs only this simple interface to connect to any EPICS variable.
You DON'T need OPC nor Shared Memory Variables nor Network variables nor NI IO Service nor any other service to get and set EPICS variables in your VI.
It's not necessary to create a LabVIEW? project to use this interface.
No problem to create an executable of your VI and to distribute it.
EPICS time stamp, status and severity are bound to resulting values.
Epics variables are available as cluster:
* Values as string array
* Values as double array
* Size of array
* Type of received data
* Status of values as string
* Status of values as integer
* Severity of values as string
* Severity of values as integer
* EPICS time stamp as string
* EPICS time stamp as integer
"CA Lab" is open source and works with all LabVIEW? versions from 7.1 to 2009. It has been tested under Windows XP® and Windows 7®.
It should be no problem to compile source code under Linux.
For more information about CA Lab, please see our page http://www-csr.bessy.de/control/SoftDist/CA_Lab/
Re: CA Lab - New interface between LabVIEW™ and EPICS Jack
Prev: Re: Waveform Record Device Support Till Straumann
Next: RE: Waveform Record Device Support graham.cox
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS BOY and 16-bit Images? Kasemir, Kay
Next: Re: CA Lab - New interface between LabVIEW™ and EPICS Jack
