1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Burt problem on Fedora 11 64 bit for EPICS Base version 3.14.11
To: [email protected]
Cc: Ramu Denduluri <[email protected]>
Date: Fri, 11 Jun 2010 09:44:14 -0500
Hi Ramu,
On Thursday 10 June 2010 18:08:00 Ramu Denduluri wrote:
>      I am getting following error when I used burt restore tool, burtwb
> ERROR: BurtProcessSnapshotFile() string column >ControlName< not in file
>  >/tmp/CLS2010-159-0608-114007.gz100610-122455-30608clsop51<
> The above command is called like "burtwb -f
> tmp/CLS2010-159-0608-114007.gz100610-122455-30608clsop51"
> I am using the latest version of burt, which is 20080801 with Epics Base
> Version 3.14.11 on Fedora 11 64 bit operating system. I tried the burt
> version, 20070626 and the behavior is the same. Also, I tested on Fedora
> Core 8 with 32 bit operating system and there it is working fine, but I
> need to make it work for Fedora 11 64 bit. Could anyone help me in
> fixing the issue?
For now you should be able to run the 32-bit linux-x86 binary on your linux-
x86_64 system and it should work properly (I suggest just copying the binary
from extensions/bin/linux-x86 to extensions/bin/linux-x86_64).  I suspect we
will need burt to work on 64-bit systems here at the APS, so Janet has it on
her list to look at and fix.
Similar advice applies to any other tools that don't work on 64-bit systems,
although we might not need them ourselves so help with fixing these is usually
welcome (but email tech-talk before starting in case someone has already done
it and just hasn't released the result).
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Burt problem on Fedora 11 64 bit for EPICS Base version 3.14.11 Ramu Denduluri
Prev: Burt problem on Fedora 11 64 bit for EPICS Base version 3.14.11 Ramu Denduluri
Next: labCA 3.3 released Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
