If your USB/Serial adapter creates a Termios-style device in /dev then you can treat it just like an ordinary local serial port.
The system creates such /dev entries dynamically when the USB/Serial adapter is detected. On my OS X machine, for example, plugging in an adapter results in
/dev/tty.PL2303-000013FA
being created.
On Jun 18, 2010, at 1:55 PM, [email protected] wrote:
> Hello,
> is there any set of library to interface with a USB (serial) device?
> It seems that asyn can interface with drvAsynSerialPortConfigure() to /dev/ttyUSB0 device files... How are those files generated? ( I have /dev/usbXX on my machine. Are those the same?)
> http://panda-wiki.gsi.de/cgi-bin/view/DCS/EPICSstartUsingStreamDev?CGISESSID=f078faedad4d8cc21b90c29c392f3319
> With usb-net module, I can trick the linux OS to create ethernet interfaces which are indeed USB ports. I could therefore have asyn connect using drvEthernetPortConfigure() (??) as well.
> http://www.embedded.com/story/OEG20021217S0036
> What do you recommend?
> PS: Is anyone streaming lots of data (video, adc, etc) over USB?
> Emmanuel
Eric Norum
[email protected]
- USB driver emmanuel_mayssat
Driver Support Tutorial Andrew Wagner
<2010>
2025
2026
<2010>
2025
2026
