Hi Dirk,
On Tuesday 22 June 2010 09:05:51 Dirk Zimoch wrote:
> I just found that the function ellFree does not exist any more in EPICS
> base 3.14.11. It has been replaced with a macro and the function
> ellFree2. Unfortunately, that means that binaries compiled with 3.14.8
> cannot run with a 3.14.11 library. Until 3.14.8, the libraries were
> always backward compatible. (Binary compatible!, not only source code
> compatible).
We only try to keep source code compatibility, which 3.14.11 mostly does.
That's why we always tell people they must do a 'make rebuild' after changing
any configure/RELEASE file. The fact that you've managed to avoid doing so is
pure luck; it would certainly not apply if we made a change to the fields in
dbCommon. I would *never* recommend relying on binary compatibility between
past releases because we haven't had that as a goal, and I'm certain nobody
tests the code for it. If binary compatibility is important enough you are
welcome to test for it in between official releases and report any issues that
you find (especially the -pre release versions), but I can't promise that
we'll always accept patches that are just to maintain binary compatibility.
> I looked for a good reason for this change but I could not find any code
> in base that calls ellFree2 (expect for the test code). Can someone
> please tell me what was the reason for this incompatible change?
The original ellFree() routine does not work properly when called from a
Windows DLL. Microsoft requires that if you allocate memory by calling one of
the standard *alloc() routines from within a DLL, you have to release that
memory by calling free() from the same DLL. This resulted in all ellFree()
calls being removed from Base, because they didn't work on Win32. I added the
ellFree2() routine to allow the DLL-specific free() routine to be passed in,
then I could make ellFree() a macro which hid that requirement from the user.
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
- ellFree vs ellFree2 Dirk Zimoch
Re: Problems configuring 4 IK320 cards Ron Sluiter
<2010>
2025
2026
CSS BOY / scripting / XY Graph John Dobbins
<2010>
2025
2026
