Andrew,
did you check the results of searching the tech-talk archives [1] for
"openmotif"?
Have a look and then reconsider how much you want to get involved.....
Cheers,
Ralph
[1] http://www.aps.anl.gov/epics/tech-talk/index.php
On Tue 22 Jun 2010 16:30:11 Andrew Wagner wrote:
Thanks Eric,
Unfortunately I ran into the pitfall of attempting to install
openmotif form source via http://www.openmotif.org/ . I was able to
compile openmotif and install the programs but unfortunately its
Makefile and the EPICS/extensions Makefile are incompatible. They seem
to expect libraries to be built with different rules and put in
different locations. The .h files medm needed where in
openmotif-2.3.0/lib not /include and a library file libXm.a appears to
never be built with the Makefile from openmotif.org
<http://openmotif.org> . I get the error:
No rule to make target
`/Users/andrewwagner/OpenMotif/openmotif-2.3.0/lib/libXm.a'
Does anyone have experience installing openmotif from source? There
must be a way to do this on a Linux box. For the time being I can just
delete openmotif and reinstall from Darwin ports.
Cheers,
Andrew
On Jun 22, 2010, at 9:16 AM, Eric Norum wrote:
I have the fink openmotif3 2.2.4-4 package installed on my OS X
machine. Seems to work well with MEDM, EDM, StripTool and SDDSplot.
MEDM is an extension:
Download the extensions configuration files from EPICS Extensions
Config Files
<http://www.aps.anl.gov/epics/extensions/configure/index.php>
Unpack the config file tarball.
cd to the extensions directory created by unpacking the tarball.
This directory will be referred to as the extensions <TOP> from now on
Edit the configure/RELEASE file top refer to where you have EPICS
base installed.
Edit the configure/os/CONFIG_SITE.darwin-x86.darwin-x86 file and set
up the correct references to your X11 and Motif packages.
cd to the <TOP> directory and run make
Now to download and build an extension -- medm in this case:
Download the medm tarball: MEDM 3.1.4
<http://www.aps.anl.gov/epics/download/extensions/medm3_1_4.tar.gz>
cd to the <TOP>/src directory and unpack the medm tarball
cd to the <TOP>/src/medm directory and run make
On Jun 21, 2010, at 6:06 PM, Andrew Wagner wrote:
Hey guys,
I'm new to EPICS and have compiled both EPICS base and Asyn
successfully on my OS X 10.6.3 MacBook Pro. It seems that much of
the driver support includes pre-made MEDM screens. Is there a good
how-to manual for installing MEDM on OS X (or any os)? I've searched
tech-talk and there definitely seem to be some pitfalls. For
instance Motif 2.30 should be used instead of 2.32 to avoid some odd
behavior. Thanks very much for the help.
Andrew Wagner
Eric Norum
[email protected] <mailto:[email protected]>
- Re: MEDM installation instructions Andrew Wagner
- MEDM installation instructions Andrew Wagner
- Re: MEDM installation instructions Eric Norum
RE: CSS BOY / scripting / XY Graph Chen, Xihui
<2010>
2025
2026
<2010>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
