1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: strange ioc hangup
To: [email protected]
Date: Wed, 23 Jun 2010 09:39:08 -0400
I had seen a similar error on MVME162 processors many years ago, in a non-EPICS environment.
I worked with WRS to try to resolve it, or work around it - unsuccessfully.
In the end, we moved these processors to an isolated network -
separate from other VME processors - to minimize the volume of
network traffic they were exposed to. We never saw the problem after that.
My (hand-wavy) conclusion is that the network driver for the MVME162
can get "overwhelmed" and lock up under certain circumstances - nothing
(necessarily) to do with EPICS.
HTH -- Larry
On 6/23/2010 9:19 AM, Benjamin Franksen wrote:
> From the console log:
CAS: request from 192.168.21.6:46187 =>  "CAS: Missaligned protocol rejected"
[Sun Jun 20 05:23:20 2010]CAS: Request from 192.168.21.6:46187 =>  cmmd=49320
cid=0x91f87157 type=48940 count=5064 postsize=5587
available=0xcb45c46e 	N=1 paddr=0x0
[Sun Jun 20 05:23:20 2010]CAS: invalid (damaged?) UDP request from
192.168.21.6:46187 ?
[Sun Jun 20 05:23:30 2010]interrupt:
[Sun Jun 20 05:23:30 2010]ei0: reset
This is base 3.14.8.2 and VxWorks 5.4.2. Looks like one or more corrupt UDP
packages arrived at the IOC. The problem is that after the last message
("ei0: reset") the IOC is dead to the network (neither transmits nor
receives anything). No way to recover, other than rebooting.
The question is: what does the CA server do after it outputs these error
messages? Could it be it does something to the socket that makes vxWorks
throw up hands and strike? Also, note the 10 second delay between the CAS
message and the vxWorks message.
Is this a known bug in VxWorks? In the CAS?
Cheers
Ben
Re: strange ioc hangup Ralph Lange
strange ioc hangup Benjamin Franksen
Prev: strange ioc hangup Benjamin Franksen
Next: Re: strange ioc hangup Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
