1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Pfeiffer Turbo Pump device driver
To: Tech Talk <[email protected]>
Date: Fri, 25 Jun 2010 14:56:47 +1000
Hi all,
   We have a Pfeiffer Turbo Pump, model TSH071E, and wish to communicate with it.
Has anyone developed a device driver and/or stream device protocol files that could be
used, or a similar driver/protocol files that could be used a starting point?
  Also I found:
while doing research. Can anyone confirm (or deny) that this is the correct protocol
specification to use?
Regards
Andrew Starritt
Principal Controls Engineer
Australian Synchrotron
800 Blackburn Road, Clayton, Victoria 3168, Australia
Tel: + 61 3 8540 4164    Fax: + 61 3 8540 4200
E-mail: [email protected]
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
Re: Pfeiffer Turbo Pump device driver Dirk Zimoch
Prev: RE: Problems configuring 4 IK320 cards Linda.Pratt
Next: Re: strange ioc hangup Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SNMP and APC rack power distribution units Robert Petkus
Next: Re: Pfeiffer Turbo Pump device driver Dirk Zimoch
