1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: No PLT for relocation
To: [email protected]
Date: Mon, 28 Jun 2010 15:03:55 +0200
I have some additional information on my problem
(found on http://www.redhat.com/docs//manuals/enterprise/RHEL-4-Manual/gnu-assembler/cris-syntax.html, thanks to B.Kolb)
When generating position-independent code (SVR4 PIC) for use in cris-axis-linux-gnu shared libraries, symbol suffixes are used to specify what kind of run-time symbol lookup will be used, expressed in the object as different relocation types. Usually, all absolute symbol values must be located in a table, the global offset table, leaving the code position-independent; independent of values of global symbols and independent of the address of the code. The suffix modifies the value of the symbol, into for example an index into the global offset table where the real symbol value is entered, or a PC-relative value, or a value relative to the start of the global offset table. [...]
GOT
Attaching this suffix to a symbol in an instruction causes the symbol to be entered into the global offset table. The value is a 32-bit index for that symbol into the global offset table. The name of the corresponding relocation is R_CRIS_32_GOT. [...]
PLT
This suffix is used for function symbols. It causes a procedure linkage table, an array of code stubs, to be created at the time the shared object is created or linked against, together with a global offset table entry. The value is a pc-relative offset to the corresponding stub code in the procedure linkage table. This arrangement causes the run-time symbol resolver to be called to look up and set the value of the symbol the first time the function is called (at latest; depending environment variables). It is only safe to leave the symbol unresolved this way if all references are function calls. The name of the relocation is R_CRIS_32_PLT_PCREL. [...]
GOTPLT
Similar to PLT, but the value of the symbol is a 32-bit index into the global offset table. This is somewhat of a mix between the effect of the GOT and the PLT suffix; the difference to GOT is that there will be a procedure linkage table entry created, and that the symbol is assumed to be a function entry and will be resolved by the run-time resolver as with PLT. The relocation is R_CRIS_32_GOTPLT.[...]
... so does this mean shared libraries are used although
-Wl,-Bstatic -static-libgcc
is used?
Again any help is welcome.
Peter
Dr. Peter Zumbruch wrote:
Hello everybody,
I am trying to cross compile and link an application based on stream device and asyn
with patched base 3.14.10 on a linux-x86_64 system with the linux-cris_v10 as target.
Stream and Asyn have been compiled for the host and target architectures.
When building the application the final linking for the target failes with this command
(which I just split up for better reading, and paths shortened <..>):
cris-g++ -o streamHadcon
-Wl,--strip-all
-L<IOC_TOP>/lib/linux-cris_v10
-L<EPICS_HOME>/base/lib/linux-cris_v10
-L<EPICS_HOME>/modules/soft/StreamDevice/lib/linux-cris_v10
-L<EPICS_HOME>/modules/soft/asyn/asyn-4.11a/lib/linux-cris_v10
-Wl,-rpath,<IOC_TOP>/lib/linux-cris_v10
-Wl,-rpath,<EPICS_HOME>/base/lib/linux-cris_v10
-Wl,-rpath,<EPICS_HOME>/modules/soft/StreamDevice/lib/linux-cris_v10
-Wl,-rpath,<EPICS_HOME>/modules/soft/asyn/asyn-4.11a/lib/linux-cris_v10
-L<AXIS_TOP>/target/cris-axis-linux-gnu/lib
-L<AXIS_TOP>/target/cris-axis-linux-gnu/usr/lib
streamHadcon_registerRecordDeviceDriver.o streamHadconMain.o
-lstreamHadconSupport
-lrecIoc
-lsoftDevIoc
-lmiscIoc
-lrsrvIoc
-ldbtoolsIoc
-lasIoc
-ldbIoc
-lregistryIoc
-ldbStaticIoc
-lca
-lCom
-lstream
-lasyn
-lpthread
-lm
-lrt
resulting in this output:
<EPICS_ASYN>/lib/linux-cris_v10/libasyn.a(devAsynInt32.o): In function `getIoIntInfo':
epicsTypeClass/../../asyn/devEpics/devAsynInt32.c:288: undefined reference to `epicsRingBytesCreate'
[..]/cris-axis-linux-gnu/bin/ld: <EPICS_ASYN>/lib/linux-cris_v10/libasyn.a(devAsynInt32.o): No PLT for relocation R_CRIS_32_GOTPLT against symbol `epicsRingBytesCreate' from .text section
[..]/cris-axis-linux-gnu/bin/ld: final link failed: Bad value
collect2: ld returned 1 exit status
Notes:
- But 'epicsRingBytesCreate' is defined in libasyn.a(devAsynInt32.o), (cris-)nm gives consistent results
- Unfortunately in addition I do not fully get the meaning of the error
- It does compile for linux-x86_64
- base itself needed an independent patch for _64 architecture in base CONFIG.linux-x86_64.linux-cris(_v10/32) copy linux-x86 (to be committed soon)
Since I did the port of EPICS to cris,
has anybody else seen such a response or something similar when cross building an application?
Any help appreciated,
Thanks, Peter
 Dr. rer. nat. Peter W. Zumbruch
 EE - department / Controls group / GSI
 E-Mail: P.Zumbruch_at_gsi.de
 Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
 GSI Helmholtzzentrum für Schwerionenforschung GmbH
 Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
 Gesellschaft mit beschränkter Haftung
 Sitz der Gesellschaft: Darmstadt
 Handelsregister: Amtsgericht Darmstadt, HRB 1528
 Geschäftsführung: Professor Dr. Dr. h.c. Horst Stöcker,
 Christiane Neumann, Dr. Hartmut Eickhoff
 Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
 Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
No PLT for relocation Dr. Peter Zumbruch
Prev: No PLT for relocation Dr. Peter Zumbruch
Next: Re: No PLT for relocation Dr. Peter Zumbruch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
