Hi Gorka,
You need to chose which architecture to build for. The ones I have used are cygwin-x86, and win32-x86. cygwin-x86 requires that you install the Cygwin package, while win32-x86 requires the Microsoft VC compiler (plus perl and GNU make, which I get from Cygwin).
You build your EPICS application just as you would for Linux or vxWorks. The EPICS build system will create a Windows executable (.exe) file which is your application. You then start that application and pass it the name of a startup script (st.cmd) that configures your IOC.
I typically modify <base>/configure/os/CONFIG_SITE.win32-x86.win32-x86 and CONFIG_SITE.cygwin-x86.cygwin-x86 to contain the lines
SHARED_LIBRARIES=NO
STATIC_BUILD=YES
so that the .exe file is standalone and does not require a lot of DLLs to run it. I find that makes distribution to non-development systems easier, but that's a personal preference.
Sent: Fri 7/16/2010 5:36 AM
To: [email protected]
Subject: Soft IOC on Windows PC
Hi all,
Can anyone tell me what steps to take to create a Soft Or 'Host-based' IOC on a Windows PC? The PC will control a board connected via RS-232. I have to use StreamDevice device support with its interface to asynDriver?
Thanks in advance
Gorka Ronda
- RE: Soft IOC on Windows PC Jeff Hill
- Soft IOC on Windows PC Gorka Ronda
RE: areaDetector problem John Dobbins
<2010>
2025
2026
<2010>
2025
2026
