1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics on ARM linux
To: [email protected]
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 19 Jul 2010 13:33:43 +0100 (BST)
On Fri, 16 Jul 2010, [email protected] wrote:
> I am currently using epics/linux on x86 intel processors. Is there any
> reason why epics/linux wouldn't be supported on arm processors? (linux
> is but any issue to be expected with epics?)
> Is anyone embedding their IOCs in their controlled hardware?
The Libera Electron Beam Position monitors, which we use at Diamond, uses
an embedded ARM PXA255 processor.  The EPICS driver can be found at
	http://controls.diamond.ac.uk/downloads/libera/
The main issue to pay attention to is that floating point support on the
ARM is very weak.  It is useful, if possible, to use the more recent EABI
calling convention to avoid the cost of emulating floating point.  More
importantly, take care to avoid using floating point in large waveform or
other high rate calculations.
Other than that the ARM is a very nice device to program, with a truly
exceptional assembler model.
Epics on ARM linux emmanuel_mayssat
Prev: Re: Epics on ARM linux David Dudley
Next: Re: Epics on ARM linux tanushyam bhattacharjee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Driver for Agilent 34970A Andrew Wagner
