1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Build error. GNU make downgrade?
To: "Gorka Ronda" <[email protected]>, <[email protected]>
Date: Thu, 22 Jul 2010 10:02:45 -0500
You don’t want to downgrade to 3.80.  You need 3.81, but there were several versions on Cygwin that were labelled 3.81, at least one of which did not work.
You can get a gzipped file with the version I am using at
http://cars.uchicago.edu/software/pub/make.gz
From: [email protected] [mailto:[email protected]] On Behalf Of Gorka Ronda
Sent: Thursday, July 22, 2010 3:37 AM
To: [email protected]
Subject: Build error. GNU make downgrade?
Hi all,
I have build EPICS Base 3.14.9 on a PC with Windows XP, Microsoft Visual C++ 2008 Express Edition, cygwin 1.7.5-1, Active Perl 5.10.1 and the GNU make 3.81 that comes in the cygwin packet.
I’m trying to create the Example IOC Application from the EPICS Application Developer’s Guide with command window, but when I build it with make, I have the following Error:
*** multiple target patterns.  Stop.
I have read in the mailing list that could be because the GNU make 3.81 doesn’t recognize DOS paths and I want to downgrade cygwin’s GNU make to 3.80. How can I do that? I have downloaded the tar file and now?
Maybe someone have the same Error, but has used another solution.
Thanks in advance,
Gorka
Build error. GNU make downgrade? Gorka Ronda
Prev: Re: Multiline input to drvAscii? Maren Purves
Next: A patch for libXpm.a (was Re: edm : TwoDProfileMonitorClass : cropping/resizing image) Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build error. GNU make downgrade? Gorka Ronda
Next: copying output of Linux ioc to file Patrick Thomas
