1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: streamDev - ENUM Converter (%{string0|string1|...})
To: [email protected]
Date: Fri, 23 Jul 2010 17:09:09 +0200
Hi all,
I have problems reading the output from my serial device using streamDev
my protocol is
thr_low_valid_intr {
    Terminator  = LF;
    cc="thr_low_valid";
    in $recvKey $cc" %*x %{INVALID|VALID}";
my record is:
record(bi, "etrax201:RLTH:thr_low_valid") {
field(DESC, "thr low valid")
field(SCAN, "I/O Intr")
field(DTYP, "stream")
field(INP, "@hadcon_RLTH.proto thr_low_valid_intr() $(device,undefined)")
field(VAL, "0")
field(ZSV, "MINOR")
field(ZNAM, "INVALID")
field(ONAM, "VALID")
"device" set in st.cmd
but the result (var streamDebug 1) is that VALID or INVALID is not recognized:
2010/07/23 16:52:35.449 hadcon AsynDriverInterface.cc:983: AsynDriverInterface::asynReadHandler(etrax201:RLTH:thr_low_valid, buffer="RECV RLTH thr_low 0x40 VALID<0a>", received=29 eomReason=NONE) ioAction=AsyncRead
2010/07/23 16:52:35.451 hadcon StreamCore.cc:910: StreamCore::readCallback(etrax201:RLTH:thr_low_valid, status=StreamIoSuccess input="RECV RLTH thr_low 0x40 VALID<0a>", size=29)
2010/07/23 16:52:35.452 hadcon StreamCore.cc:967: StreamCore::readCallback(etrax201:RLTH:thr_low_valid) inputBuffer="RECV RLTH thr_low 0x40 VALID<0a>", size 29
2010/07/23 16:52:35.454 hadcon StreamCore.cc:989: StreamCore::readCallback(etrax201:RLTH:thr_low_valid) inTerminator <0a> at position 28
2010/07/23 16:52:35.456 hadcon StreamCore.cc:1056: StreamCore::readCallback(etrax201:RLTH:thr_low_valid) input line: "RECV RLTH thr_low 0x40 VALID"
2010/07/23 16:52:35.457 hadcon StreamCore.cc:1076: StreamCore::readCallback(etrax201:RLTH:thr_low_valid) async match failure: just restart
2010/07/23 16:52:35.459 hadcon AsynDriverInterface.cc:674: AsynDriverInterface::readRequest(etrax201:RLTH:thr_low_valid, 4000 msec reply, 500 msec read, expect 0 bytes, asyn=yes)
2010/07/23 16:52:35.464 hadcon AsynDriverInterface.cc:1067: AsynDriverInterface::asynReadHandler(etrax201:RLTH:thr_low_valid) readMore=0, ioAction=AsyncRead
The rest of the protocol is working just this function not, why?
Any suggestions appreciated,
best regards,
Peter
Dr. rer. nat. Peter W. Zumbruch
EE - department / Controls group / GSI
E-Mail: P.Zumbruch_at_gsi.de
Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführung: Professor Dr. Dr. h.c. Horst Stöcker,
Christiane Neumann, Dr. Hartmut Eickhoff
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
RE: streamDev - ENUM Converter (%{string0|string1|...}) peter.owens
Prev: Building host-based applications for cross-compiled targets Rod Nussbaumer
Next: Re: Building host-based applications for cross-compiled targets Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Building host-based applications for cross-compiled targets Andrew Johnson
Next: RE: streamDev - ENUM Converter (%{string0|string1|...}) peter.owens
