1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Developing of record / driver / device support? Asyn?
Date: Wed, 28 Jul 2010 08:56:59 -0400
Gorka,
This is the blind leading the blind, but I suspect you're in luck...
Eric Norum has written a really nice tutorial:
http://www.aps.anl.gov/epics/modules/soft/asyn/R4-12/HowToDoSerial/tutorial.pdf
which contains gems such as this one:
"If you’re using a serial line directly attached to the IOC you need something like:
            drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
            asynSetOption("L0", -1, "baud", "9600")
            asynSetOption("L0", -1, "bits", "8")
IOW, a lot of your work is already done.
You don't "need" SynApps, but you will need ASYN.
I found the  terminology a little confusing at times, but it mostly means there is a ton of useful stuff available.
Specifically, I believe you will be using devGPIB, and it took me a while to figure out which part of it is actually GPIB specific, and which part has GPIB in the nomclature for historic reasons.  You'll see what I mean when you dig into it.
Cheers    -Mathias
From: [email protected] [mailto:[email protected]] On Behalf Of Gorka Ronda
Sent: Wednesday, July 28, 2010 6:34 AM
To: [email protected]
Subject: Developing of record / driver / device support? Asyn?
Hi all,
I’m newbie to EPICS and I need some help to start using it. I’m trying to develop an IOC based on a Windows XP PC. I have already build EPICS Base 3.14.9 with win32-x86 architecture and execute the “Example IOC Application” and “Channel Access Host Example” from the Application Developers Guide.
Now, I would like to connect a card to the IOC (PC) via RS-232. I think I need the Asyn interface from SynApps. But, I have no clear how to do it. I have to program something or a generic support for any RS-232 connection is already made? Does it change depending on the card to be used? What would I need? Record, Device and Driver support? Some of those? One of those? Maybe, another solution…
On the other hand, when I have to develop the database? Before or after record/driver/device support? How to do it simply and fast?
Thanks in advance
Gorka
Developing of record / driver / device support? Asyn? Gorka Ronda
Prev: RE: channel archiver steve.singleton
Next: Re: Analog output device support design Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Developing of record / driver / device support? Asyn? Gorka Ronda
Next: RE: Developing of record / driver / device support? Asyn? Mark Rivers
