1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.?
To: [email protected]
Date: Thu, 5 Aug 2010 18:14:04 +0000
I am in the process of trying to package EPICS base 3.14.11 into
native package format on several commercial UNICES, but I can't
find a nice way to have it install into a standard tree:
  $INSTALL_PREFIX/
    +-- bin/
    |    '-- {binaries and scripts go here}
    +-- db/
    |    `-- softIocExit.db
    +-- dbd/
    |    `-- {dbd files}
    +-- doc/
    |    '-- html/
    |         `-- {html documentation}
    +-- include/
    |    `-- {C and C++ header files}
    +-- lib/
    |    +-- {compiled libraries}
    |    `-- perl-5.8.8/
    |         `-- {perl modules}
    `-- templates/
         `-- {template files}
If I change INSTALL_LOCATION to be anything other than $(TOP)
then make fails to find any sources to link, and there don't
appear to be any installation rules to relink the libraries
and binaries at install time -- nearly all other programs I've
packaged provide a 'make install' rule for this purpose.
I've got a kludgy workaround that finds lines in the build.log
file beginning 'g++ -o', and calls the installed libtool script
to relink targets that match into the install tree structure above
without leaving references to directories or libraries in the build
tree in RPATH entries.
Is there a way to install a runtime EPICS base into the root
directory using the existing build system?
Thanks in advance for your help!
Cheers,
Gary V. Vaughan ([email protected])
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Ralph Lange
RE: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Davidsaver, Michael
Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Andrew Johnson
Prev: Re: FW: Making a case for cases Ralph Lange
Next: Re: How do I install to $prefix/EPICS/bin, $prefix/EPICS/lib etc.? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Making a case for cases Chestnut, Ronald P.
