1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks and Radius Authentication
To: Gary Carr <[email protected]>
Date: Thu, 05 Aug 2010 15:11:53 -0400
Why would you let people log into IOCs?
Console access via terminal server is more useful for debugging (as it - other than login - allows access during the boot sequence), and I would consider it safer to just disable remote login completely. (Frees memory on your IOCs, too.)
If you put a console access service (such as conserver [1]) on top of the serial line/terminal server connection, you are not on vxWorks anymore, and authenticating against Radius gets a lot easier.
Ralph
[1] http://conserver.com/
On 05.08.2010 14:54, Gary Carr wrote:
Is anyone using a Radius server to provide login authentication for their VxWorks IOCs? I did a search on Tech-Talk, but only saw a reverence to Radius authentication to a terminal server connected to the IOCs.
Re: VxWorks and Radius Authentication Andrew Johnson
VxWorks and Radius Authentication Gary Carr
Prev: Re: Making a case for cases Purcell, J. David
Next: Theweb site for the EPICS October meeting is now open. http://www.bnl.gov/epics/ Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: VxWorks and Radius Authentication Gary Carr
Next: Re: VxWorks and Radius Authentication Andrew Johnson
